November 24, 2010 at 5:27 am #156729
I have downloaded the latest version from this site, I used QS for installation.
I uploaded every single file, no errors shown. Installation went fine, however when I load the frontend
I get this error
Even worse, if I go to the admin and check configuration for the template I get all JS errors and cannot work
My Joomla is updated to the most recent version
These errors are in IE 7, also in FF 3
Don’t know what’s going on.
Can anyone help me?
November 24, 2010 at 10:22 am #364102Now please go to the template’s configuration and disable the Optimize JS function, and then provide the link to your site , we will check and resolve the issue
thanks
November 24, 2010 at 12:51 pm #364121<em>@tienhc 205108 wrote:</em><blockquote>Now please go to the template’s configuration and disable the Optimize JS function, and then provide the link to your site , we will check and resolve the issue
thanks</blockquote>
Hello
I want to try that but remember that If I go to the template configuration section, that JS won’t let me change because of the error, is there another way? I checked “params.ini” at /MY_FOLDER/templates/ja_anion
Still the same.
November 24, 2010 at 3:48 pm #364134I tried moving this template to another host, in this case Hostgator, the other one is in Godaddy. Administrator is working fine, however it does still show a Javascript error, but options are working fine.
I also realized that at the front end, I disabled the Twitter module and JS error was gone.
I am worry because it’s not working at Godaddy and it does at HG
What could be wrong?
Saguaros ModeratorSaguaros
November 25, 2010 at 3:23 am #364193<em>@javierramirez 205146 wrote:</em><blockquote>I tried moving this template to another host, in this case Hostgator, the other one is in Godaddy. Administrator is working fine, however it does still show a Javascript error, but options are working fine.
What could be wrong?</blockquote>
It’s so difficult to give you exact answer on the issue, can you please provide me the link to your site, i would like to check for Javascript conflicts if any ?
Viewing 5 posts - 1 through 5 (of 5 total)This topic contains 5 replies, has 2 voices, and was last updated by Saguaros 13 years, 12 months ago.
