  • thongta Friend
    #163559
    Hi everyone,
    I’m working on a JAT3 based Joomla template, and having a problem with JAxhtml module style.
    Please look at this screenshot:
    It works just fine with below format:
    <h3>
    <span>module title</span>
    </h3>
    <div class="ja-box-ct clearfix">
    module content
    </div>
    In the other site of mine with the same template, I got other layout with below format:
    module content
    (nothing else but module content)
    Here is the layout code:
    <?xml version="1.0" encoding="utf-8"?>
    <layout name="desktop">
    <!--Extra css load for this layout-->
    <stylesheets>
    </stylesheets>
    <block name="header" type="header"></block>
    <block name="mainnav" type="mainnav" main-inner="1"></block>
    <block name="topsl" type="spotlight" main-inner="1" style="JAxhtml">user1,user2,user3</block>
    </blocks>
    <blocks name="middle">
    </blocks>
    <block name="botsl" type="spotlight" main-inner="1">user6,user7,user8,user9,user10</block>
    <block name="footer" type="footer"></block>
    </blocks>
    </layout>
    Please advise.
    T
    1. Screenshot
    pritam Friend
    #389724
    Can you give your site url to solve the problem. Explain the problem with reference to the site.
    thongta Friend
    #389729
    <em>@pritam 238429 wrote:</em><blockquote>Hi,
    Can you give your site url to solve the problem. Explain the problem with reference to the site.</blockquote>
    Thanks for your reply.
    The working version is: http://stage.foobla.com username: friend, password: foob.la
    The non-working version is: http://foobla.com
    Please keep in mind that both are the same source code & configuration.
    Thanks,
    T
    pritam Friend
    #389768
    I could not reproduce your problem on my installation. Can you please PM me admin access to http://foobla.com to check the problem.
This topic contains 4 replies, has 2 voices, and was last updated by  pritam 13 years, 8 months ago.
