  • Alva Chew Friend
    #143450
    I am using Joomla version 1.5.13 with JA Nickel template version 1.0.
    Everything is working fine except some hiccups with the JCalPro component. I have attached the screenshots of the calendar when using JA Nickel component and when using a default Joomla component.
    Somehow, the <td> bgcolor that shows the calendar category colors appear when using the default Joomla template, even the default JA Purity that comes with it, but not when using JA Nickel.
    We have not made any changes to any of the template files except the CSS files. We have previosly used JA_Fedora with Joomla version 1.5.7 & the same version of JCalPro and has no issue (See here), so am really baffled.
    Would greatly appreciate if someone can tell me what’s causing the issue.
    Thanks!
    1. default
    2. bug
    Alva Chew Friend
    #314205
    Hi Guys, finally found the style that is making the background disappear. It’s just a background transparent style in the addon.css which i did not notice.
    Anonymous Moderator
    #314210
    Hi stridecsys
    I think you should contact to the author of JCalPro component. He will help you to solve it.
This topic contains 3 replies, has 2 voices, and was last updated by Anonymous 15 years, 3 months ago.
