  • coalition Friend
    #177307
    I had installed JCE editor on Wally, and the updater dialog and options dialog buttons/icons bring up a new page without the ability to save. All of the options for the specific dialog functions are there, but none of the buttons to save the options are there.
    Walt.
    doparedes07 Friend
    #453909
    hi i had the same problem, i fixed turn in disabled the lazyload plugin when i setting up de JCE, after that turn the plugin enabled again, and all works fine for me. 🙂
    coalition Friend
    #454076
    Thanx, I should have tried that before posting. It seems the lazyload plugin is messing with a lot of things.
    Walt.
    Ninja Lead Moderator
    #454480
    What JCE version do you install on your site? I have tested JA Wall with com_jce_2020.zip version and it works well.
    coalition Friend
    #454550
    I have .23 currently.
    #454668
    Please PM me link to download JCE version and admin access of your site. I will check it on your site.
    Giulio Orsi Friend
    #454779
    <em>@coalition 320813 wrote:</em><blockquote>I had installed JCE editor on Wally, and the updater dialog and options dialog buttons/icons bring up a new page without the ability to save. All of the options for the specific dialog functions are there, but none of the buttons to save the options are there.
    Walt.</blockquote>
    happened on my site too, and I can’t install the editor plugins
    Joso
    coalition Friend
    #454904
    Solution: disable plg_lazyload and the reinstall jce and its plugins.
    #454942
    I spent entire time to test with JCE new version but i can not replicate error you have mentionedt, please give me download link for JCE version which is in conflict with plg_lazyload plugin.
    I will check and debug the same.
    John Wesley Brett Moderator
This topic contains 10 replies, has 5 voices, and was last updated by  John Wesley Brett 12 years, 6 months ago.
