April 20, 2011 at 9:04 am #162995
I’m testing the extension JComments in a site with JA Purity 2 template: when I click on the “add comment” link (near the “read more” link, in the category view, to read all the article), the article’s page is showed, but there’s a strange shift of the margin top, and the title (h2) of the article is partially covered.
The problem is similar to this reported in the JComments forum:http://www.joomlatune.com/forum/index.php/topic,1785.0.html
The problem appears in Firefox, Chrome, IE8 but NO in IE6.
The problem appears only in JA Purity 2, not in other templates (JA Purity 1 works fine, for example).Has anyone had the same problem?
Did you find a solution?thanks
Don Lee FriendDon Lee
- March 2010
- 274 times in 238 posts
April 22, 2011 at 3:58 am #387576Hi,
Thanks for your report. I’ve informed team to check and fix it soon!
April 22, 2011 at 8:17 am #387609If you solve the problem, could you report the solution here?
I mean the CSS changes needed to solve it.thanks
- March 2010
April 22, 2011 at 8:30 am #387611<em>@andresb 235784 wrote:</em><blockquote>If you solve the problem, could you report the solution here?
I mean the CSS changes needed to solve it.thanks</blockquote>
Please follow this report to keep track of fix progress http://pm.joomlart.com/browse/JATCPURITYII-106
May 3, 2011 at 1:42 pm #389645Hi there. I had exactly the same problem with jcomments, but with different template. After i read another topic i finally solved it, the problem was in my template.css, in main body area in particular. So in template.css, in area “xx_main”, i changed command “overflow: hidden;” to “overflow: visible;”. Now when i’m in joomla blog format, and click “add comment”, the article title is OK and in position. I hope that’s useful.
- March 2010
May 4, 2011 at 10:24 am #389783Thanks dtsilog, I will try it now 🙂
May 6, 2011 at 3:01 pm #390131It works in Firefox (3.x and 4.x) and IE 8 (not tested in IE 7), but it causes problems in IE 6; the right column now it’s shifted down.
I can’t try Chrome and Safari at the moment…May 7, 2011 at 3:10 pm #390251You ‘re welcome both. Maybe if you delete the entire command.
From
.column { overflow: hidden; float: left; }
to
.column { float: left; }
I tested and it seems ok in firefox 3, internet explorer 8-9 and chrome.
May 9, 2011 at 9:30 pm #390457thanks, but again it doesn’t work in IE 6.
It’s known that IE 6 had some problems with “overflow”.
The fact is that there’s still some traffic from IE 6 (something like 6-7% of users at least), so this is not the best solution at the moment.Don Lee FriendDon Lee
- March 2010
May 10, 2011 at 9:10 am #390532<em>@andresb 239421 wrote:</em><blockquote>thanks, but again it doesn’t work in IE 6.
The fact is that there’s still some traffic from IE 6 (something like 6-7% of users at least), so this is not the best solution at the moment.</blockquote>you should encourage your users to upgrade their browser http://ie6countdown.com/join-us.html
June 10, 2011 at 5:29 pm #395750hi, I see from here that the bug is fixed: http://pm.joomlart.com/browse/JATCPURITYII-106
is it possible to see the solution, I mean how to fix it?
thanks
This topic contains 13 replies, has 3 voices, and was last updated by andresb 13 years, 5 months ago.
