  • sentix Friend
    #1016021
    Hi, I try to use with JForm a field type radio and class attribute "btn-group" to style it as buttons. Unfortunately, this doesn’t work as expected. Is it because the template uses BS3 instead of Joomlas BS2?
    What can I do (how do I have to change the markup) to style the radio inputs as buttons?
    Thanks in advance for your help!
    regards,
    Manfred
    Pankaj Sharma Moderator
    #1016264
    The template is purely based on BS3 as It demanded and latest for now.
    Can u turn on the Legacy compatibility from template options and see if it helps you.
    If not share the screenshot of issue and URL of page Here.
This topic contains 1 reply, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 9 months ago.
