  • fmfame Friend
    #192022
    Hello look at the picture. If i want to resize picture avatar the thumnail live view at the bottom does not work properly. look at the picture.
    With standard protostar template that works fine..
    1. Bildschirmfoto-2013-11-04-um-19.15.18
    phong nam Friend
    #511498
    Hi fmfame,
    In this case, you can set the resized size of avatar picture on Jomsocial wall by creating a custom.css file at templates/ja_fixel/css/ path and put below css style into:
    #community-wrap img {
    width: 110px;
    fmfame Friend
    #511553
    I have done but the problem already exists.
    I think that it is anything with a “max-width:none” css line, which is overridden from the template style.. in fixel template
    i found this:
    and in protostar template where i dont have any problems i saw this:
    Now you can see that in element.style is the max-width:none line overridden by anything…
    Now i tried this in fixel template:
    look at the line at img { .. i inactivated the max-width:100% and the max-width:none from element style is active and the problem is solved.
    But i can not change in template the important img{} css styles..
    What could i do now without changing this important parameter?
    What could that be..? Or how could i set in the community style first priority or anything..?
    1. Bildschirmfoto-2013-11-07-um-23.39.44
    2. Bildschirmfoto-2013-11-07-um-23.40.57
    3. Bildschirmfoto-2013-11-07-um-23.43.06
    4. Bildschirmfoto-2013-11-07-um-23.45.29
    phong nam Friend
    #511563
    Hi fmfame,
    <blockquote>What could i do now without changing this important parameter? What could that be..? Or how could i set in the community style first priority or anything..?
    </blockquote>
    You can override the max-width of our template image by open components/com_community/templates/default/css/style.css file:
    body #cWindow img{max-width:100%;width:auto9;height:auto;vertical-align:middle;border:0;-ms-interpolation-mode:bicubic}
    Then change max-width:100%; to max-width: none !important;
    fmfame Friend
    #511661
    no the css style.css is already by element.style overridden..
    tried it but i have to change img in template.css in ja_fixel
    phong nam Friend
    #511908
    Hi fmfame,
    I have tried to resize the avatar thumbnail of Test user and it worked fine. In addition, i also realized that you put a incorrect css property in /templates/ja_fixel/css/themes/light/template.css at lines:
    img {
    max-width: auto !important;
    It should be none or a fixed property, not auto.
    fmfame Friend
    #512365
    No thats not the solution!
    If i do this, then i got viewing problems on home grid..
    This is with the img {max-width: auto which is standard in ja fixel
    And this is with the img {max-width: none}
    1. Bildschirmfoto-2013-11-15-um-13.31.29
    2. Bildschirmfoto-2013-11-15-um-13.30.59
This topic contains 7 replies, has 2 voices, and was last updated by  fmfame 11 years ago.
