  • Andre Prior Friend
    #143403
    since I upgraded jomsocial to latest version 206 iam getting a huge problem with the popup window. When I try to add a video, the popup window is fixed (was before scrollable) now the text is longer than the box and I cant see or reach the buttons.
    Please see:
    Here is the standard bubble theme, and the popup is correct.
    Aswell the linespace is too huge. How to I minimize them like in the bubble theme?
    Andre Prior Friend
    #313948
    Hello? Support? I need help! Thankyou!
    SP Media Friend
    #313949
    It takes them a little more than an hour to get to topics. 🙂
    It looks like a generic CSS issue, probably a float: left being overridden.
    Andre Prior Friend
    #313973
    Well, its urgent now since its a coporate website. What is wrong with the support here? Why are the templates not updated to latest version? I surely wont continue my membership if nobody is willing to help me.
    mfcphil Friend
    #313977
    Submit a support ticket….if its a template issue the developers will help.
    http://support.joomlart.com/index.php?_m=tickets&_a=submit
    Andre Prior Friend
    #314204
    Well, I posted a support ticket, which as delegated to their design team, then it was closed and I havent got any help or solution. This is really frustrating me. We pay for working templates. Its not good when templates are not updated in the same moment when the core got updates.
    If you create templates for 3. party plugins, you’ll have to support and need to update them when the plugin got updates. Otherwise your templates are senseless and just a way to burn money imho.
    Its now a few days and I havent gotten a solution, nor feedback, nor help. You telling us you only bring out 1 template per month to push the quality and support. What I see is a “standard” new template and no support 🙁
    magnusb Friend
    #314257
    I’ve been waiting for several weeks with no luck, not even a reply from a developer. When I submitted a ticket, I was told I would get a reply in my forum post, still no go. They seem to be referring us back and forth between ticket system and forum, though neither actually gives results. Sorry to highjack your thread, but I am getting really frustrated at this, and I am very close to giving up getting my issues fixed…
    Anonymous Moderator
    #314468
    I am sorry for my delay.
    We are tried to solve this issue. Jomsocial component updated the latest version. And current you does not support this version in our template.
    For the reason, i am afraid that you have to handle the changes at your end.
    We will try to update our template with the latest version of jomsocial in the further.
    Anonymous Moderator
    #314469
    Phill Moderator
    #314477
    If this is such an important site then why did you update a key component without testing it?
    Provide a link to the affected page and maybe someone in the community may be able to help?
    Andre Prior Friend
    #314484
    Thanks for the reply even its not sadly not helpful. You should post a warning to the template that its currently not supporting latest version of jomsocial. Hopefully you are able to update the template asap. thanks.
    Phill Moderator
    #314491
    It could have been helpful had you posted a link to the affected page. Having a link would mean I could take a look at the problem.
    And why shoild I post a warning?
    Andre Prior Friend
    #314654
    the devs should post a warning to the JA Sulfur that its currently not working with the latest Jomsocial component. Iam in deep contact with the jomsocial devs and they assured its a template mistake.
    Why I dont put a link to the affected website? I wish I could but the website is not viewable from the interweb. Its a intranet website with runs on domestic servers behind a firewall and with no access to a DMZ.
    We will switch nut to gavickpro template which supports the latest jomsocial version. thank you and byebye.
    Phill Moderator
    #314667
    I think it is a minor css tweak that is needed to fix this but as I do not have jomsocial and am not going to buy it to test this I cannot help. It would probably only take a couple of minutes to fix if I could see it but as I cannot…
    Good luck.
This topic contains 14 replies, has 6 voices, and was last updated by  Phill 15 years, 4 months ago.
