Viewing 4 posts - 31 through 34 (of 34 total)
  • HeR0 Friend
    #496843
    Hi Melanieb,
    To be frank, i saw it works from my last check. Now, i don’t know why it does not work.
    Could you pls detail me whe you did customizations for further checking ?
    melanieb Friend
    #496989
    Hi Hero,
    the customising I have done are in the form fields where I added my own fields, also in the jajomsocial plugin to change Employer and Job Seeker to Organisation and Volunteer, and to change the fields in the Jomsocial Custom Profiles to match these in the user type. I personally have never see it work for me in that it puts the details in the back end, although I know and appreciate it did for you.
    I uploaded a fresh copy of the job board yesterday to see if this helped but it hasn’t made a difference – it is saving everything to the database which is the odd thing
    melanieb Friend
    #497005
    Hi Hero,
    I am thinking it might be best if I uninstall the job board and start again as its too corrupted – would you agree this would be best and sort my issues out? It’s just unfortunate that I have put so much work in to creating all the fields etc.I don’t suppose there is a quick way of adding the fields without having to re-do them all?
    HeR0 Friend
    #497255
    Dear Melanieb,
    I am going to mark this thread as solved issue. Please get back to me with new thread or follow up with this thread http://www.joomlart.com/forums/topic/jobs-employers-jobseekers-not-saving-in-front-or-back-end-although-do-in-database/
This topic contains 34 replies, has 2 voices, and was last updated by  HeR0 11 years, 5 months ago.
