charles99 Friend
charles99
- December 2008
- 50 times in 6 posts
November 12, 2010 at 10:56 pm #156371I just installed the JA Social Template and Jomsocial 1.8.11 and my Profile Comment Wall is lining up in the wrong place. I am attaching a photo that points out the css problem and hope someone can post a fix..
thanks
Saguaros ModeratorSaguaros
November 13, 2010 at 7:42 am #362702sorry, in your case, please provide me the link to your site and the administrator account , i would like to check the issue in detail
thanks
charles99 Friendcharles99
- December 2008
November 14, 2010 at 4:03 am #362815<em>@tienhc 203347 wrote:</em><blockquote>sorry, in your case, please provide me the link to your site and the administrator account , i would like to check the issue in detail
thanks</blockquote>
I have fixed the problem…
thanks! Now if you can tell me how to remove the Content Block on the frontpage only that would be a big help! After you do everything in your earlier post it leaves a small white box right in the center of the page where the article frontpage use to be…
I am not using articles on my frontpage so this is why I need to remove this white box. And if you say yes to hide the content block in the template settings it disable all the component area throughout my site and none of my components will load or show.
So I need a fix for this without be directed to another post that states solved when its not!
aman204 Friendaman204
- January 2010
- 418 times in 356 posts
November 15, 2010 at 6:51 pm #362955<blockquote>Now if you can tell me how to remove the Content Block on the frontpage only that would be a big help! </blockquote>
1) You can go on to create new profile in template parameters::
http://wiki.joomlart.com/wiki/JA_T3_Framework_2/Guides#Profiles
and select hide for content block for this profile
2) Then, You can select home menu item for the new profile in Profile Override Settings
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 3 voices, and was last updated by aman204 14 years, 1 month ago.
Jomsocial Wall lining up in wrong place!
