  • alioztr Friend
    #180454
    I installed jaminisite 1.5
    I want to install joomfish for multilanguage
    But when i want to install joomfish, joomla says :
    Component Install: Another Component is already using directory: “/home/___/public_html/administrator/components/com_joomfish”
    2 times i installed joomla minisite, but 2 times web page said same error.
    What should i do.
    Ninja Lead Moderator
    #466170
    Sometime i work with joomfish component i got the same error. I used to delete it by manual. Find source code and delete “com_joomfish” then try to reinstall it. Hope this way helps you install com_joomfish sucessfully
This topic contains 2 replies, has 2 voices, and was last updated by  Ninja Lead 12 years, 3 months ago.
