July 8, 2008 at 11:59 pm #130604
I just updated to Joomla 1.5.4 from 1.5.3 and now the first icon (PDF, Print, E-Mail) is centered on an article page, with the others off to the right-hand side as they should be. If I choose to display all three icons, PDF icon is centered. If I hide the PDF icon, then the Print Icon is centered.
I’ve also been experimenting with JA Pollux, JA Nerine, JA Hedera and JA Purity. The same problem occurs in all of these JA templates except JA Purity. Also, it does not occur in the templates packaged with Joomla (rhuk_milkyway or Beez.)
Any thoughts on why this might be happening? :confused: I really like JA Iris and was hoping to use it…
Thanks in advance!
Menalto FriendMenalto
- May 2007
- 531 times in 361 posts
July 9, 2008 at 1:33 pm #258778Can you give your site url?
July 10, 2008 at 3:37 am #258894I’m actually experiencing it on a standalone pc I use as my development system. I have not upgraded to Joomla 1.5.x on my live site yet, but I am planning to load Joomla 1.5.4 on my live server soon; when I do so I will let you know.
I can attach a screenshot or two, if you think that would help. Also, the Joomla 1.5.4 upgrade has created situations for some users (including me) where two titles appear on articles. I note that when there are two titles, the second title “pushes” the icons to the right, where I normally expect to see them. When I remove either of the duplicate titles per the recommendations in the Joomla Forum thread ( http://forum.joomla.org/viewtopic.php?f=430&t=306067 ), the first icon moves to the center of the page as described in my initial post.
As a last note, I mentioned that JA Purity does not experience this issue. I realized after I posted my initial question that I did not install JA Purity on my test website. It turns out, Joomla has included JA Purity as one of the three default templates with the new version (1.5.4.)
Thanks…
Sherlock FriendSherlock
- 2478 times in 2162 posts
July 17, 2008 at 9:06 am #260460Hi Very good if you can send your URL
July 23, 2008 at 9:55 pm #261842Same problem
after version 1.5.4 installed ( patch 1.5.3 ) the icon print is center ( tested with IE and Firefox )
the html code is correct
.. td align=”right” width=”100%” class=”buttonheading” ..
Template JA_Purity print icon ok but not JA_Iris
URL : http://www.medeco-ch.com/index.php?option=com_content&view=article&id=5&Itemid=8
This topic contains 5 replies, has 4 voices, and was last updated by ezwww 16 years, 6 months ago.
