July 25, 2011 at 4:57 pm #166690
Dear team
i am using ja teleline iv.
pls check the error
Fatal error: Cannot instantiate abstract class JDatabaseQuery in /disk1/ulagatam/public_html/plugins/system/jat3/jat3/core/menu/base.class.php on line 329kindly help to resolve the problem
Phill ModeratorPhill
- February 2014
- 2206 times in 1818 posts
July 25, 2011 at 9:48 pm #402985I have upgraded your plugin to version 1.3.0beta and now your site is functioning. Please check and iff needed you can roll back using the JA Extension Manager.
The problems you are experiencing are because you have upgraded your site to J1.7 and JA have not yet released J1.7 compatible versions of all their templates and extensions.
July 26, 2011 at 2:31 am #403007<em>@phill luckhurst 255545 wrote:</em><blockquote>I have upgraded your plugin to version 1.3.0beta and now your site is functioning. Please check and iff needed you can roll back using the JA Extension Manager.
The problems you are experiencing are because you have upgraded your site to J1.7 and JA have not yet released J1.7 compatible versions of all their templates and extensions.</blockquote>
No my problem is not solved..
http://amudambooks.com/index.php?option=com_booklibrary&view=categories&layout=categories&Itemid=473
check here
- February 2014
July 26, 2011 at 9:14 am #403064What is the problem on that page?
As previously stated, the JA templates are not yet released for J1.7 and the fix I applied just gets things running. There will probably still be errors.
JA are working hard on getting all their templates and extensions up to date and that should be soon. However, you may find that some of your third party extensions also need updating and for those you will need to speak to whoever provided those.
July 26, 2011 at 9:30 am #403070thanks for your reply.
after template changing its working well. if am waiting for your template when its released.July 26, 2011 at 9:38 am #403074thanks for your reply.
after template changing its working well. if am waiting for your template when its released. -
This topic contains 6 replies, has 2 voices, and was last updated by selvamurali 13 years, 5 months ago.
