  • vrooom Friend
    #165091
    I am trying to install an extension that functions as a bar that always appears on my website, unfortunately there is a conflict with MooTools.js script and jQuery script (which the bar uses, it is an extension plug in) I was given some HTML code that would probably solve this issue by loading jQuery before MooTools, but I do not know where to find it. I know that I must place it after the <HEAD> tag in my HTML code. That is all I was told.
    thangnn1510 Friend
    #395806
    Please add js code:
    jQuery.noConflict();
    to your JQuery files. That will help you to prevent conflict of 2 frameworks. More detail please follow this:
    http://api.jquery.com/jQuery.noConflict/
    Thanks.
This topic contains 2 replies, has 2 voices, and was last updated by  thangnn1510 13 years, 5 months ago.
