July 14, 2012 at 9:04 am #179085
In Joomla 1.5 edenite template, it is easy to do split menu and left-side submenu. I just add submenu in main menu, but in Joomla 2.5 your edenite template shows sub menu under the splitemenu.
Please help me how to show the submenu in left side.
HeR0 FriendHeR0
- August 2011
- 588 times in 549 posts
July 16, 2012 at 4:07 am #460973Hi Norito
You should use mega menu which is supported full on this template.Regards,
Saguaros ModeratorSaguaros
July 16, 2012 at 4:25 am #460977Hi norito,
JA Edenite template with joomla 2.5 has JAT3 system plugin and it includes new menu system: mega menu which not include in JA Edenite template with joomla 1.5. If you want it to be the same with version 1.5, please change menu type in Backend > Template manager > Your default template > Profiles (tab) > Menu settings
And let me know if you need further helps.
July 17, 2012 at 1:15 am #461077Thank you, Saguaros again. Please see the attached. This setting is done initially but the result is not what I expected.
Edenite template J2.5 does not provide what is supposed to perform as the splitmenu.My client has asked me to migrate J15 to J25 with JA-Edenite template. The client uses JA-edenite in J1.5. That is why I can not use Mega-menu even if I want to.
July 17, 2012 at 2:06 am #461084Dear norito,
You can build a demo through our demo builder: http://www.joomlart.com/demo/#templates.joomlart.com/ja_edenite
I’ve tried to install both in J!1.5 and J!2.5 and it works properly. If you already done with upgrading your site to J!2.5, PM me url and admin account, I shall check this for you.
July 17, 2012 at 1:04 pm #461166I will check and let you know.
Thanks.
Norito
July 17, 2012 at 1:19 pm #461168HeR0 FriendHeR0
- August 2011
July 18, 2012 at 2:57 am #461231Hi Norito
The Edenite 2.5 template only supports stylesheet for mega menu. So i guess you should use mega menu.
The current site is using dropline menu as your attachment.Regards,
<em>@norito 330398 wrote:</em><blockquote>Please see the current split menu at my site.</blockquote>
July 18, 2012 at 6:58 am #461246Please look at this site. I used Split Menu and have come to this point so far.
I have two issues:
1. I would like to get rid of the pull-down menu which is not part of splitmenu
2. I only want to show child menu not all the menu.
HeR0 FriendHeR0
- August 2011
July 18, 2012 at 7:19 am #461252HI Norito
That is impossible, sorry.Regards,
July 18, 2012 at 9:16 am #461285Hi norito,
You need some heavy customization on this menu system and it’s beyond of our scope. Our support scope is limited to bug fixing and helping users get demo site alike setup. Hope you understand us.
July 18, 2012 at 9:29 am #461291How come there is split menu in menu setting? If it is impossible, Split menu should be deleted in the template menu.
July 18, 2012 at 10:01 am #461304Thanks. I already sent a ticket to Joomlart.com
July 20, 2012 at 1:32 am #461551I have solved #2 issue. The only issue left is #1. I think this should be fixed by Joomlart.com, template maker.
<em>@norito 330508 wrote:</em><blockquote>Please look at this site. I used Split Menu and have come to this point so far.
I have two issues:
2. I only want to show child menu not all the menu.</blockquote>
AuthorPostsViewing 14 posts - 1 through 14 (of 14 total)This topic contains 14 replies, has 3 voices, and was last updated by norito 12 years, 5 months ago.
