  • designorama Friend
    #977940
    After upgrading to latest Joomla (3.6.3) Website returns "HTTP ERROR 500" error.
    Webhost provided the error from the log:
    PHP Fatal error: Cannot redeclare class vmrouterhelper in /xxx/xxx/public_html/components/com_virtuemart/router.php on line 713
    Access to the Administrator area is OK and running the latest Virtuemart component as well.
    Any thoughts.
    Pankaj Sharma Moderator
    #977946
    This seems to be a problem from Virtualmart and Joomla , I suggest you do not update the Joomla of the live site since all the extension and templates are not ready for it .
    You can also post the issue on Virtualmart forum , so they will check this problem .
    dataqube Friend
    #978458
    I was able to temporarily solve this by renaming the
    components/com_tcpdf/router.php to router.php.unused
    Note that I have not test the VM PDF functionality yet
    #978472
    You can post the issue on extension support forum so they can check it , Beside i suggest you to do not update live site and wait for template release for Joomla 3.6.3 .
This topic contains 3 replies, has 3 voices, and was last updated by  Pankaj Sharma 8 years, 1 month ago.
