mazhar shah Friend
mazhar shah
- 8 times in 5 posts
June 15, 2017 at 4:03 pm #1042102Just installed fresh Joomla 3.7 and Masthead 1.3 (latest version which comes with JaHealth template).
Problem is in Admin, when creating Masthead Menu items on successive lines (rows).
- Add a new ‘Menu Item’, plus ‘Masthead title’ plus ‘description’ and ‘background image’ on line 1. All is ok.
- Click the + sign on the right and a fresh row of boxes appears underneath.
- YOU CANNOT ADD A NEW ‘MENU ITEM’ IN THE BOX. When you try, it adds the newsmenu item ONLY IN THE TOP ROW AGAIN.
- Doesnt matter how many new rows you add by clicking the + sign, even if you try to add a new menu item in the very bottom row, many inches below the top row, the menu item is always added to the very top row.
So I deleted the Masthead v.1.03 and uploaded the older version I had from before (1.02) just to check. This had the same problem. In Joomla 3.6 all was fine. In Joomla 3.7 this problem exists for Masthead 1.02 and Masthead 1.03.
Saguaros ModeratorSaguaros
June 16, 2017 at 4:10 am #1042217Hi,
I just tried to add some new item in backend settings of JA Masthead module but it worked properly: http://prntscr.com/fkd0ov
You can put your site online and share me the credentials so I will take a look.
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 1 reply, has 2 voices, and was last updated by Saguaros 7 years, 6 months ago.
Joomla 3.7 and Masthead 1.03 problem (and 1.03 same problem joomla 3.6 is ok)
