  • slowlyjam Friend
    #1091289
    Hello
    Please, How and where do I setup features for the JoomlArt Advanced Custom Module?
    It seems like this module is a super extension and user for many different things.
    I notice that the features of JoomlArt Advanced Custom Module in this template are different for the Ja Law template.
    How and where are these features setup?
    I need to use some of the features in the Ja Law template.
    I am asking for your guidance,
    Thank you.
    Kind Regards
    Flavius
    Hi Flavius,
    JA Law uses different types of JA ACM module, you can check out the documentation of this template for the details of configuration of each module: https://www.joomlart.com/documentation/joomla-templates/ja-lawfirm#homepage
    slowlyjam Friend
    #1091432
    Thank you, Saguaros.
    Two questions please:
    1. What photo display/gallery module does JoomlArt have?
    2. What is the best method of Backing up a Joomla 3 site. Thanks.
    Kind Regards
    Flavius
    • This reply was modified 6 years, 10 months ago by  slowlyjam.
    slowlyjam Friend
    #1091718
    Any reply, please?
    iammontoya Friend
    #1091752
    I’ll reply, since they do take forever. They don’t really have a cool gallery. I like Simple Image Gallery, but there are dozens out there.
    I like to use Akeeba Backup. I wouldnt change it for the world.
    You can seek for a suitable extension for gallery in Joomla extension directory and yes, Akeeba Backup is good option.
This topic contains 5 replies, has 3 voices, and was last updated by  Saguaros 6 years, 10 months ago.
