  • Saguaros Moderator
    #971419
    I think it displays properly, how you want it should be?
    rafjon Friend
    #971447
    Have you look at the image I posted? Can you see how the text on the left? There is a big N in one line and in next line there is ÆSTI VI. If I change this text from "Næsti viðburður" to "Upcoming Events" it shows up like in the demo.
    Can you tell me where in the code this cutting of the words happens? Because I’m using non-English language the cutting of the word is strange.
    Also where in the code can I change the date format?
    Could you update the login info of your site: URL, Admin & FTP account? I will check it for you.
    rafjon Friend
    #971807
    rafjon Friend
    #971987
    I have fix this. I found where to change to date from Y-m-d to d.m.Y. Found the file under templates/ja_charity/acm/countdown/tmpl/style-1.php.
    I also found a way to fix the problem where the module title was split and only the first char was in first row and the rest of the title in next row. I ended using jQuery.
This topic contains 5 replies, has 2 voices, and was last updated by  rafjon 8 years, 1 month ago.
The topic ‘JoomlArt Advanced Custom Module in JA Charity – 1 issue to fix and 1 question’ is closed to new replies.
