  • slowlyjam Friend
    #1091610
    Hello
    I am trying to setup tabs in this template butI am not seeing ACM Block type – TABs.
    Please, what is the best way to setup tabs?
    Thanks.
    Kind Regards
    Flavius
    slowlyjam Friend
    #1091719
    Any reply, please?
    Pankaj Sharma Moderator
    #1091967
    This template does not have this type of ACM. You need to customisation to add it from other templates.
    As example Here
    Each template has its own ACM files based on template style and structure.
    Moving the style from other templates need customisation to make it ready for the template in which you are importing the ACM file.
    slowlyjam Friend
    #1092081
    Thank you, Pankaj,
    Please, how do I do this?
    Guide me through this procedure, please.
    Kind Regards
    Flavius
    #1092191
    Here is the guide for how to use ACM file in other templates.
    slowlyjam Friend
    #1092202
    Thank you, Pankaj.
    I looked at guide but it is not showing me how to move an ACM feature from one template to another.
    The template already have the ACM module, but not a particular feature.
    #1092203
    Hi You can move the folders inside the ACM folder, For example, Tabs.
    :copy the folder: templates/uber/acm/tabs to your Joomla template folder: your_site_root_folder/templates/your_template/acm/.
    But each template has its own ACM so in case it not work you need to debug the code how its defined in other templates and decode it on your template. It happened in some cases.
    slowlyjam Friend
    #1092204
    Thank you, Pankaj.
    Please direct me to the folders and areas that I need to move.
    I will try it.
    #1092233
    I already explain the steps in my last reply, There is no additional steps kindly read my post and documentation again to use ACM in other templates.
This topic contains 8 replies, has 2 voices, and was last updated by  Pankaj Sharma 6 years, 10 months ago.
