Leon Cuzzilla Friend
Leon Cuzzilla
- 5 times in 1 posts
August 26, 2015 at 5:29 am #665641Still pretty sure something to do with javascript conflicting: http://matilda.net.au/matjoomla/media/jui/js/jquery.min.js
I can’t say exactly when it happened but it was after upgrades to joomla 3.4.3, T3 framework and latest Uber templateLeon Cuzzilla FriendLeon Cuzzilla
August 26, 2015 at 5:29 am #746625Still pretty sure something to do with javascript conflicting: http://matilda.net.au/matjoomla/media/jui/js/jquery.min.js
I can’t say exactly when it happened but it was after upgrades to joomla 3.4.3, T3 framework and latest Uber templateNinja Lead ModeratorNinja Lead
- November 2014
- 3854 times in 3563 posts
- November 2014
August 28, 2015 at 12:49 am #680355Ok thanks. Hope it’s fixed asap as really excited to get our new site up live and that feature was perfect for our Apple products.
August 28, 2015 at 12:49 am #746841Ok thanks. Hope it’s fixed asap as really excited to get our new site up live and that feature was perfect for our Apple products.
October 9, 2015 at 6:02 am #751079Hello. Did anything happen with the fix? I can’t see any updates on here http://pm.joomlart.com/browse/JAECACMMOD-51
I tried another jacm module tabs to see if I could use that instead but it only worked when I had module on the page. See here http://matilda.net.au/matjoomla/index.php/macbook-12-inch and if I put another one it stopped working – see here http://matilda.net.au/matjoomla/index.php/macbook-pro – if you click on the last module it starts moving the one above. Is there anything else I can use as it looked really good with one of these JACM modules and I really want to get the site live. 🙂Ninja Lead ModeratorNinja Lead
- November 2014
October 9, 2015 at 9:20 am #751105Yes, You can use this way to work with the problem on your site first. About the status issue, I just reminded development team. They will check and fix it soon
October 13, 2015 at 12:46 am #704729Ok thanks cos I can’t get any of the JACM tab modules to work with the template at the moment.
October 13, 2015 at 12:46 am #751451Ok thanks cos I can’t get any of the JACM tab modules to work with the template at the moment.
- November 2014
October 14, 2015 at 9:03 am #704995<em>@imatilda 497088 wrote:</em><blockquote>Ok thanks cos I can’t get any of the JACM tab modules to work with the template at the moment.</blockquote>
Developer checked the problem on your site and it is from System – Reset SEF Base and System – SEF plugins on your site.
After disabling them, you will see the tabs are working fine on your site, you can PM me FTP account of your site. I will forward development to check and find the solution to fix this bug on your site.
- November 2014
October 14, 2015 at 9:03 am #751633<em>@imatilda 497088 wrote:</em><blockquote>Ok thanks cos I can’t get any of the JACM tab modules to work with the template at the moment.</blockquote>
October 16, 2015 at 3:40 am #705384I will PM you details now. Thanks
October 16, 2015 at 3:40 am #751858I will PM you details now. Thanks
- November 2014
October 16, 2015 at 8:45 am #705426<em>@imatilda 497667 wrote:</em><blockquote>I will PM you details now. Thanks</blockquote>
I had backend account of your site. But I need FTP account to access source code from your hosting, please pm me FTP account.
This topic contains 33 replies, has 2 voices, and was last updated by Ninja Lead 9 years, 1 month ago.
