  • idhla Friend
    #827671
    When I set the More News (setting for Links in the admin) in the JoomlArt Advanced Custom Module to 0, it affects the rest of my site. If I set the Links to be any number 1 or more, then the site looks fine. But if I set the links to 0, in hopes of only having the slideshow without the ‘More News’ links, it completely messes up the front page. The items in the sidebar disappear and the rest of the front page loses its alignment (see screenshots).
    Has anyone else encountered this or can anyone suggest a fix?
    1. Untitled-14
    2. Untitled-23
    Adam M Moderator
    #828733
    Hi @idhla,
    I’ve just reported an issue so our development team can check this matter, please stay tuned while we’re working on it.
    Best regards,
    Adam.
    idhla Friend
    #837103
    Hello, has there been any progress with this? I have installed the template several times and the issue still persists.
    Adam M Moderator
    #837960
    Hi @idhla,
    Regarding the link to bug report in my previous reply, the bug is still in development queue. I sent another request to increase the issue priority so they can check and fix it asap, please stay tuned.
    idhla Friend
    #866541
    Hi, I just checked the bug tracking and there’s a note that says the issue is fixed, but now what? Is there an update or something I should do to get this to work on my site?
    Thanks for your help.
    Adam M Moderator
    #867620
    Hi @idhla,
    As you can see the Fix Version hasn’t been set yet, which mean we fixed the problem but it hasn’t been included in any version yet. If the issue is fixed and included in new version, you should see new version via JA Extension Manager component (and you will have to update the template via that component as well), please stay tuned.
This topic contains 5 replies, has 2 voices, and was last updated by  Adam M 8 years, 10 months ago.
