  • dieudonne Friend
    #886494
    we use JA Teline V, and tried ToolTip (very important for us) We tried a lot of thing but still not working…
    So we tried with the default Joomla Template "Protostar", and it is working. http://www.vivreenbelgique.be/_veb2016/testing
    We also contacted the developper of this extension : NoNumber.
    So the conclusion is that Ja Teline V change bootstrap & javascript behavior…! https://www.nonumber.nl/forum/tooltips-pro/41140-bootstrap-javascript-conflict
    The JA templates (T3 based templates) often load scripts that do not play nice with other scripts. Not all script based extensions can work happily together. And you just found one of those situations.
    Tooltips uses the Bootstrap popover functionality and is tied to how well that plays with other scripts.
    So if your template loads stuff that causes that Bootstrap popover functionality to fail or become buggy, then there isn’t much I can do.
    So what can we do to fix this ??
    Regard.
    Hi @dieudonne,
    The admin account you provided doesn’t work, you can update it again and also send me the FTP account so I will have a look at this.
    dieudonne Friend
    #886731
    Ok now it is ok with the accound provided before.
    And for the ftp, is it ok with eXtplorer ?
    Regard.
    Hi dieudonne,
    In the testing page, as I can see that the tooltip still functions properly: http://prntscr.com/a6f2wr
    Did you get it solved?
    dieudonne Friend
    #888316
    Very strange. We change nothing. But now the click behavior isn’t working…!
    So the developper (Tooltip – NoNumber) say that :
    Tooltips is based on and uses the Bootstrap scripts and styles that come with Joomla core (Bootstrap 2). Your template prevents those file from getting loaded and replaces them with a different version of Bootstrap. These bootstrap scripts seem to not be able to cope with the scripts/syntax in Tooltips.
    Seems they are incompatible.
    So you use different bootstrap like Joomla core ?!
    What is the solution…?
    Regard.
    I tried to assign ‘Protostar’ template to the menu item ‘testing’ on your site and its behaviour is the same when use JA Teline
    Could you take a look?
    dieudonne Friend
    #889571
    No, the "on click" behavior is not working.
    real click behavior piet : {tip Tooltip Click::This is the text in the tooltip|click}This text has a tooltip{/tip}
    See my screenshot. So what can we to fix it ?
    Regard.
    1. 2016-02-23_16h48_06
This topic contains 7 replies, has 2 voices, and was last updated by  Saguaros 8 years, 10 months ago.
