  • Ryan Vu Friend
    #136330
    Hi all,
    I want to have a coupon systems to give customers discount on purchases in the following way:
    If customers spend $100 they get say $5 discount
    and if they spend $200 they get $7 discount
    and so on….
    I can would like to have the discount subtract from the shopping cart automatically or customers can type in the discount code manually but either way there has to be a price check loop
    Does anyone know how to do that? :-[
    nefar Friend
    #283315
    I don’t but someone may have brought up a similar issue on the virtuemart forums, or you may have some luck on google.
    There is a coupon system built into virtuemart but what you want would probably have to be a custom programed module.
This topic contains 2 replies, has 2 voices, and was last updated by  nefar 16 years ago.
