  • black mamba Friend
    #173966
    I have a problem with a module position on the page with JoomShopping.
    The module does not stay on the right side, but falls down
    It is interesting to work on the contact page and k2.
    Please Help!
    JoomShopping, Elastica, Joomla 2.5.1
    http://www.canecorso-stenci.com
    aspik Friend
    #438710
    <em>@black mamba 301014 wrote:</em><blockquote>Hi,
    Please Help!
    http://www.canecorso-stenci.com</blockquote>
    do not download jQuery 2 times!
    This component has its own loading jQuery. disable it in them
    Change the script the template in the
    jQuery(function(jQuery){
    var jQuerycontainer = jQuery('#ja-main');
    var curr_layout = '';
    var colW = 0;
    //detect layout width
    if (jQuery(window).width() >= 720) {
    curr_layout = 'fixed';
    colW = 240;
    } else {
    curr_layout = 'fluid';
    colW = jQuerycontainer.width() / 2;
    //init layout masonry
    jQuerycontainer.masonry({
    itemSelector: '.ja-masonry',
    columnWidth : colW,
    isAnimated: true,
    isResizable: true
    var reloadMasonry = function () {
    jQuerycontainer.masonry( 'reload' );
    //change columnWidth depend on the wrapper width, specify for this template
    jQuery(window).bind( 'smartresize.masonry', function() {
    if (jQuery('#ja-main').width() >= 720) {
    //fix width layout - reload one time
    if (curr_layout != 'fixed') {
    jQuerycontainer.masonry( 'option', { columnWidth: 240, isResizable: true } );
    } else {
    //update column width
    jQuerycontainer.masonry( 'option', { columnWidth: jQuerycontainer.width() / 2, isResizable: false } );
    //reload layout
    // Check bricks height changed - relayout
    jQuery(function (){
    //store height for all bricks
    jQuery('.ja-masonry').each (function(i, el){
    var el = jQuery(this);
    el.data('h', el.height());
    //interval check
    jQuerycontainer.data('interval-timer', setInterval(function () {
    //detect change on masonry bricks height
    jQuery('.ja-masonry').each (function(i){
    if (el.data('h') != el.height()) {
    reloadMasonry ();
    return false;
    }, 2000));
    </script>
    black mamba Friend
    #438737
    Long live aspik !!!
    Double jQuery load is crucial thing.
    I didn’t use your script.
    I didn’t know where is the file should be applied for.
    I found a solution on the JoomSopping forum.
    http://www.webdesigner-profi.de/joomla-webdesign/joomla-shop/forum/posts/26/1495.html?lang=en
    insert if (!$load)
    File; /components/com_jshopping/lib/factory.php
    Line; #136
    Function; loadJsFiles()
    function loadJsFiles(){
    static $load;
    if (!$load){
    $document =& JFactory::getDocument();
    if (!jQuery) {
    $document->addCustomTag('<script type = "text/javascript" src = "'.JURI::root().'components/com_jshopping/js/jquery/jquery-1.6.2.min.js"></script>');
    $document->addCustomTag('<script type = "text/javascript">jQuery.noConflict();</script>');
    $document->addCustomTag('<script type = "text/javascript" src = "'.JURI::root().'components/com_jshopping/js/jquery/jquery.media.js"></script>');
    $document->addCustomTag('<script type = "text/javascript" src = "'.JURI::root().'components/com_jshopping/js/functions.js"></script>');
    $document->addCustomTag('<script type = "text/javascript" src = "'.JURI::root().'components/com_jshopping/js/validateForm.js"></script>');
    $load = 1;
    but your help was very useful for me.
    Thanks again.
This topic contains 3 replies, has 2 voices, and was last updated by  black mamba 12 years, 10 months ago.
