test melih
 melih
  • slavonec Friend
    #179281
    Hi guys,
    I’m really stuck. Would like some advice from you.
    Is there any incompatibility between Joomla and Joomshoping component?
    I’m trying to get rid of the slideshow module on the internal pages, but that is not happening.
    I copied default layout to a new one without the slideshow block, then created new profile with that new layout and on the “page assignment” assigned the default profile only to the front page and the no-slideshow profile to the rest of the menus. But, no success at all.
    Also I cannot see in the drop down “Page Assignment” com_jshop, thus I cannot pick it. Where can I add that component to the “Page Assignments”????
    Any recommendations / help would appreciate.
    thank you in advance
    swissa Friend
    #461707
    It would be useful if you posted a url so that the problem can be seen.
    In the meantime I suggest you install akeeba and do a backup so that you have one. 🙂
    Which version of JS are you running?
    slavonec Friend
    #462328
    Thank you for the fast response.
    I updated the TEMPLATE and everything acts as it suppose to. The problem disappeared. You guys fixed something. I do not know. Maybe you should investigate that.
    Thank you
This topic contains 3 replies, has 2 voices, and was last updated by  slavonec 12 years, 6 months ago.
