  • jonatha2 Friend
    #172292
    Hello
    I have successfully installed the JA Tiris theme onto a new test site.
    I am at the final two stages:
    1) Installing JoomShopping
    2) Installing Kunena Forum
    However, upon going to the Extention Manager for both I get the following error message (I am only uploading the zip files contained within the CUSTOM directory of the theme download):
    JInstaller: :Install: Cannot find XML setup file
    Additionally, when I click on the Download Joomshopping component in the JA Tirus userguide, it loads the Joomla Extension website and it shows that the component has been removed! See: http://extensions.joomla.org/extensions/e-commerce/shopping-cart/5378
    Hopefully someone can help.
    Jonathan
    TomC Moderator
    #431940
    I guess my first question would be . . .
    Why go through all of this trouble when you can utilize the Quickstart + Sample Data Installation Process
    – which installs all of the components for you?
    :confused:
    jonatha2 Friend
    #431946
    Because I wanted to create a clean install. However, that aside, I would expect the components (as downloaded from the JoomlArt site) to work as per the Userguide instructions?
    Jonathan
    TomC Moderator
    #431947
    You are absolutely correct . . . unless, of course, it is an issue with the 3rd Party Extension Developer (which, insofar as the relationship with the JED, it apparently is).
    You can always try to download the component directly from the Developer’s website HERE
    jonatha2 Friend
    #431948
    Tom
    You are correct to an extent.
    However, the two custom zip files (as downloaded from JoomlArt) do not work. Will JoomlArt rectify this problem with their downloads – and when?
    Jonathan
    TomC Moderator
    #431952
    <em>@jonatha2 292138 wrote:</em><blockquote>Tom
    Jonathan</blockquote>
    Will I bring this to the attention of our JA Devs – Yes
    “When” will the issue be verified and (if need be) corrected – Unknown at this point in time.
    In the meantime, you can try to download the component directly from the Developer’s website HERE [/url]
    swissa Friend
    #431953
    Tom
    Hi jonatha2,
    Don’t know if it is relevant to you but I’ve had similar problems in the past so I unpacked the zip and there was a xml file in there. Turned out, for me, that the problems was a permissions one. Could be that I use OS X but fixing the permissions solved it for me and they installed fine after that.
    May not help you but thought I’d share my experience. OS X has some funny traits.
    Also you may find that the zip file contains folders i.e. one extension for Joomla 1.5 and another for 1.7.
This topic contains 7 replies, has 3 voices, and was last updated by  swissa 12 years, 12 months ago.
