amirolahmad Friend
amirolahmad
- December 2011
April 24, 2012 at 5:24 pm #176444Hye guys, can you help me out here!
I have no probs with your template before. but when i try to bind it with Cloudflare, MegaMenu, Highlight and JA Tabs didn’t work anymore. I found it cause by JS CSS minify. However, i already turn it of JS, CSS, HTML and Rocket Loader in Cloudflare but it didn’t solve my probs.
In administrator site, css won’t load in template preference so i can’t edit the preference
Printscreen: http://forum.joomla.org/viewtopic.php?t=706374&p=2775438
Did you know how to solve it?
ThanksSherlock FriendSherlock
- 2478 times in 2162 posts
April 25, 2012 at 3:53 am #450040hi amirolahmad,
Can you please post here the url where the issue can be seen ? also as you mentioned the problem maybe related to the Cloudflare extension so any response from the Cloudflare team ?
amirolahmad Friendamirolahmad
- December 2011
April 25, 2012 at 9:25 pm #450208hi dat hoang,
There is no problems with Cloudflare. They said maybe something wrong with my template. However, at this time, i need to pause the Cloudflare (temporary) because the problem still not solved.. If you need me to turn it on, just let me know here because without Megamenu working, I’ll lost my readers..
My URL is http://www.osem.my
April 26, 2012 at 2:04 am #450220Hi amirolahmad,
It’s hard to give you an advise without seeing the problem so I think you should turn the Cloudflare on or you can pm me your admin account, the FTP if possible and then I would check it myself.
- December 2011
April 26, 2012 at 8:29 am #450290Ok. I already turn the CloudFlare on..you can see it now at http://www.osem.my… Otherwise, if you need my admin account..just let me know..
April 26, 2012 at 9:20 am #450297Hi amirolahmad,
I think I would need your admin account and the FTP Info also, they are needed for further checking on the issue, can you pm me ?
- December 2011
April 26, 2012 at 9:27 am #450300ok..i will pm u now…
edit: DONE. i already give u the details.. TQ
Winchester FriendWinchester
- February 2011
- 19 times in 6 posts
April 28, 2012 at 7:28 am #450607When editing your site, do you set cloudflare to development mode for the domain? Also, the JA T3 template offers to compress your css and js files by default. You should turn these off when working on your site.
I find that it makes it difficult when you try to edit your website before doing these.
Best regards,
H. Winchester Lyon1 user says Thank You to Winchester for this useful post
- December 2011
May 5, 2012 at 7:39 pm #451636i’ve already done do it what you has been listed there. But it didn’t solve my probs. And no feedback from Sherlock Holmes.. and now i don’t know how to solve it.
- February 2011
May 5, 2012 at 9:20 pm #451642<em>@amirolahmad 317917 wrote:</em><blockquote>i’ve already done do it what you has been listed there. But it didn’t solve my probs. And no feedback from Sherlock Holmes.. and now i don’t know how to solve it.</blockquote>
Do you have cache enabled in Joomla. Is the compression turned on for CSS & JS files in your T3 template settings? Cloudflare offers these as well.
Try turning the above mentioned in Joomla and then purging the cache in Cloudflare and see if that helps.
Best regards,
- December 2011
May 6, 2012 at 8:42 am #451661I’m already turn off the cache system from the beginning in global configuration & plugin..
This is what I’ve done in my joomla preference..
image 2
Image 3
in cloudflare, I turn OFF the minify JS CSS and RocketLoader, but still facing the probs..
- Winchester Friend
Winchester
- February 2011
May 6, 2012 at 6:39 pm #451697Ok.. I see…. In Cloudflare, turn on “Development Mode” when ever you’re making changes to the website. Development Mode turns off automatically when after 3 hours, so if the changes you’re making will take more time than that, you have to go back and turn it on again.
Like I said in my previous post, it gives problems when you start to make changes to your website (especially to CSS and JS files) before turning on Development Mode in Clourflare first.
If you start making changes before turning on Development Mode, you have to Purge Cache first, before the changes can show up on your website.
Best regards,
H. Winchester Lyon2 users say Thank You to Winchester for this useful post
May 7, 2012 at 10:39 am #451836Hi amirolahmad,
I am sorry for this late reply 🙂 I now can access to your back-end but don’t know how to turn on the cloudfare to see out the problem, Could you please let me know what I need to do to check out the problem myself.
- December 2011
May 7, 2012 at 1:26 pm #451852<em>@Sherlock Holmes 318164 wrote:</em><blockquote>Hi amirolahmad,
I am sorry for this late reply 🙂 I now can access to your back-end but don’t know how to turn on the cloudfare to see out the problem, Could you please let me know what I need to do to check out the problem myself.</blockquote>
So i’ll give you the access to the cloudflare (https://www.cloudflare.com/login.html) with my account. So that, you can turn it on. I can’t let my site with cloudflare on before the probs settle. My site will ruined without JS CSS work. I’ll PM you the details.
- December 2011
May 7, 2012 at 1:27 pm #451854<em>@winchester 318005 wrote:</em><blockquote>Ok.. I see…. In Cloudflare, turn on “Development Mode” when ever you’re making changes to the website. Development Mode turns off automatically when after 3 hours, so if the changes you’re making will take more time than that, you have to go back and turn it on again.
If you start making changes before turning on Development Mode, you have to Purge Cache first, before the changes can show up on your website.</blockquote>
nothing happen..still didn’t solve my probs even the development mode ON and purge cache from cloudflare site..
AuthorPostsThis topic contains 21 replies, has 3 voices, and was last updated by Sherlock 12 years, 7 months ago.
