Sherlock
- 2478 times in 2162 posts
May 8, 2012 at 2:58 am #451938Hi amirolahmad,
I have checked the problem pretty carefully and I am afraid that its caused by cloudflare, there is a js file from the cloudflare that is loaded even before the joomla mootool library is loaded, its causing conflict, I don’t know how cloudflare is able to insert a snap of js code into your site, let me know if that js code is inserted by you, if that we would need to move it to other place to get rid of problems
amirolahmad Friendamirolahmad
- December 2011
May 8, 2012 at 1:56 pm #452040<em>@Sherlock Holmes 318292 wrote:</em><blockquote>Hi amirolahmad,
I have checked the problem pretty carefully and I am afraid that its caused by cloudflare, there is a js file from the cloudflare that is loaded even before the joomla mootool library is loaded, its causing conflict, I don’t know how cloudflare is able to insert a snap of js code into your site, let me know if that js code is inserted by you, if that we would need to move it to other place to get rid of problems</blockquote>
All the js script has been installed by CloudFlare itself. I’m not insert it. So, can you please to move it? Or i need to contact CloudFlare to tell them about the js script that you’ve been founded? Can you please tell what’s the problem and where I can find it so that I can tell CloudFlare support person..
Tq
Sherlock FriendSherlock
May 9, 2012 at 2:43 am #452123Hi amirolahmad,
yeah, I think you can contact the CloudFlare support person, just tell him about the script that’s inserted at the top of you site, it look similar like this
//<!;document.write(‘<script type=”text/javascript” src=”//ajax.cloudflare.com/cdn-cgi/nexp/v=3037830340/cloudflare.min.js”><‘+’/script>’)}}catch(a){};
//]]>amirolahmad Friendamirolahmad
- December 2011
May 9, 2012 at 4:19 am #452143it seems looks good righ now..main menu, ja tabs and headline working fine HOWEVER let me test this for 24hours for the perfect result. BUT there is still an error listed below:
1) button next, previous not working
2) article description + html coding in mouse hover
3) facebook button/scrip gone (osem network social reader) *before this, there is facebook login button in there
- amirolahmad Friend
amirolahmad
- December 2011
May 9, 2012 at 6:40 am #452169<em>@amirolahmad 318557 wrote:</em><blockquote>it seems looks good righ now..main menu, ja tabs and headline working fine HOWEVER let me test this for 24hours for the perfect result. BUT there is still an error listed below:
</blockquote>
Edited:
Dear @sherlock Holmes
I wanna say thank you very much for helping us. Now everything look perfect now.. Thank you so much.. All JS CSS has been loaded perfectly with CloudFlare ON!
Thanks again!
1 user says Thank You to amirolahmad for this useful post
May 10, 2012 at 2:58 am #452310Hi amirolahmad,
I am glad to hear that 🙂 , Can you tell me how you managed to get rid of the problem ? the CloudFlare team helped with solution?
AuthorPostsThis topic contains 21 replies, has 3 voices, and was last updated by Sherlock 12 years, 7 months ago.
