  • justlovejoomla Friend
    #132279
    Hi there are some posts here that scoot around this but none that solve my problem.
    I am trying to use mesolite for a virtuemart site.
    In the vm_module is the option to use jscook.
    I would like to use this option, but the problem is that in the firefox browser the submenus drop behind the content and modules – I have tried many z-index changes (but clearly have not found the holy grail) – does anyone know how to fix this?
    Thanks for reading
    I am happy to pm site-in-progress
    mj1256 Friend
    #265626
    did you try something extreme, like 999
    #265630
    Thanks Yes tried high z indexes – the demosite is at http://joomla.acy.com.au
    would really appreciate some help with this – the problem is only in firefox
    #265967
    HI justlovejoomla
    Do you have any successful ?
    #265983
    Hi nguoiabcd
    No not fixed / no success. – I am still having trouble with the layering of the jscook menu over tthe content – there must be an easy way to fix this – with z-index of content perhaps.
    Thanks for checking up on my problem with firefox and this template.
    url = http://joomla.acy.com.au/
    In firefox browser only, when you hover down the left-hand menu the submenus appear and these fall behind the standard content.
    Thanks for following up – hopefully this will be easy to fix / fingers crossed.
    #265993
    I view your site by FF 3.0
    and have like image
    2520
    left menu is okie
    #269642
    Thanks yes – works in ff 3 but not 2 – unfortunately – many are still using 2…
This topic contains 7 replies, has 3 voices, and was last updated by  justlovejoomla 16 years, 3 months ago.
