Viewing 14 posts - 16 through 29 (of 29 total)
  • James Weston Friend
    #436004
    ๐Ÿ™‚ what do they say “it’s easy when you know how”
    I will be interesting what responses we get re the side news. However, after looking at your site and seeing that when you click on one of the side news boxes, as well as having the article come up you also have all the catergories up as well i think I might just do that instead. Might be simpler and gives me the same result.
    Jim
    James Weston Friend
    #436018
    Hi Swissa,
    sorry to bother you again. I have added a couple of properties in the five star hotel section.
    I have not touched anything else and now when i click here http://www.myjakartaconcierge.com/index.php?option=com_jshopping&controller=category&task=view&category_id=15&Itemid=543&lang=en
    I am seeing the side news modules appearing at the bottom of the page but I HAVE TOUCHED NOTHING on the sidenews module ๐Ÿ™
    Jim
    swissa Friend
    #436019
    How did you get there?
    I look at 5* and see this.
    1. jim
    James Weston Friend
    #436023
    thats is strange. I am on a mac and I see this
    but on my iPad it is like your image?
    Jim
    1. Picture-2
    swissa Friend
    #436024
    The joy of computers.
    I have same dev environment as you and sometimes I have to clear lots of cache. There is a neat app for free called Cache Out X that clears it all. I find sometimes that a restart clears up some stuff too. Weird I know. ๐Ÿ˜‰
    James Weston Friend
    #436055
    Hi Swissa,
    It is very strange it is now doing the same thing on my iPad. Itis only in the hotel section. In the golf section it seems ok. It is really strange it happened after I was uploading an image to a hotel and my system crashed. When I check on side news it is only checked for the home page.
    If you get a chance could you look in the backend to make sure I am correct?
    Jim
    Jim
    swissa Friend
    #436143
    Hi Jim,
    I haven’t been in to your admin section and I’ve not seen this problem before with Sidenews. With Slideshow yes but not Sidenews.
    I’m going to offer some ideas that sound like I’m fumbling in the dark but these are from working with it for a while and the combination may clear your problem.
    1. Set up a new menu item for the moment and call it Shop. Make sure you set it to Products and to ALL.
    2. Delete from JoomShopping the Category Hotels.
    Clear all cache from JAT3, Joomla and your browser.
    Make a new Category in JS, add a product or so and make a menu item for it. See if it picks up sidenews. I wouldn’t think so. I hope not! ๐Ÿ˜‰
    Now, finish off making the categories before doing any more formatting on modules. Get the ‘shop’ built first. Even if you don’t fill out all the detail usw get the structure there. That should help you.
    Do a backup so that you have a restore point.
    Now you can I hope delete out the ALL products menu item although it would do really well for you as a Site map or Offers/see all menu item!
    ๐Ÿ™‚
    James Weston Friend
    #436173
    Thanks Swissa,
    That seems to have done the trick.
    With the Jshopping is it possible to display a categories list on the left hand side of the page that just has the sub categories in it from a main category?
    Also is it possible to eliminate the images that go next to the sub-category names as they appear on this page http://www.myjakartaconcierge.com/index.php?option=com_jshopping&controller=category&task=view&category_id=10&manufacturer_id=&label_id=&vendor_id=&page=&Itemid=587&lang=en so i just have the names in a type of list. (however, without deleting the images that go with the sub category names in other sections like hotels and spas.
    Jim
    swissa Friend
    #436175
    <em>@origomedia 297741 wrote:</em><blockquote>Thanks Swissa,
    That seems to have done the trick. </blockquote>
    Pleased to hear it. A weird little problem that one!
    <em>@origomedia 297741 wrote:</em><blockquote>With the Jshopping is it possible to display a categories list on the left hand side of the page that just has the sub categories in it from a main category?</blockquote>
    Not sure what you mean here – post me a url with an idea or a pic? All categories and sub categories carry IDs so you shouldn’t have any problem building menus from sub cats.
    <em>@origomedia 297741 wrote:</em><blockquote>Also is it possible to eliminate the images that go next to the sub-category names as they appear on this page http://www.myjakartaconcierge.com/in…id=587&lang=en so i just have the names in a type of list. (however, without deleting the images that go with the sub category names in other sections like hotels and spas.</blockquote>
    Need to go away and think about that one. I have a good idea but I think you would need to modify one of the Tiris modules. Not sure if I am up to that so I’ll have a poke around the php and come back to you.
    Remember to keep doing those backups regularly just in case any gremlins reappear.
    To make it easier fo me to track what I am doing can you start a new thread for each problem please Jim.
    Many Thanks
    James Weston Friend
    #436176
    Thanks Swissa,
    I have made a new post. BTW what is the simplest method to make a back up in case the gremlins come back? Is it on my hosting site?
    Jim
    swissa Friend
    #436177
    <em>@origomedia 297745 wrote:</em><blockquote>Thanks Swissa,
    Jim</blockquote>
    Install a product called Akeeba, read the documentation and to check it worked do a test restore (kickstart). (Copy the back-up file to your mac first of course). All works via the admin panel of Joomla and I know that I am not alone in saying I wouldn’t live without it! It IS a life saver!
    TzuChi Foundation Friend
    #443952
    hi, i am new to Ja tiris..
    joomla 2.5.3, joomshopping Version 3.4.2
    Do anyone know how to display a category (eg: t-shirt) in 4 products in 1 row?
    (i managed to change to 4 product to 1 row in homepage and all categories page only)
    Kindly refer to attachment.
    thank youยท
    1. homepage
    2. cat_tshirt
    swissa Friend
    #443958
    <em>@tc_sling 307885 wrote:</em><blockquote>hi, i am new to Ja tiris..
    thank youยท</blockquote>
    Hi tc_sling,
    Just so that I get it right you want to change from 3 products in a row to 4 products in a row? Is that correct?
    If so, you need to go to this page
    yourdomain/administrator/index.php?option=com_jshopping&controller=config&task=catprod
    Scroll down to ‘List products’ section
    You need to edit the ‘
    Amount of products in row’
    to 4
    AND
    you need to put a check in ‘Change “products on page” and “products in row” for all category’
    This will force a global change
    #443960
    thanks Swissa.
    i tried, and it work just what i want. ๐Ÿ˜€
This topic contains 29 replies, has 3 voices, and was last updated by  TzuChi Foundation 12 years, 9 months ago.
