  • eastline Friend
    #140447
    I emailed the RS!form component creator about this problem, some of the fields of the form aren’t working on IE and I get a “done with error” notice on IE as well, they replied that their component is operating perfectly and that the error is being triggered by ja.script.js line 67
    function equalHeight(){
    makeEqualHeight ($('el-botsl').getChildren());
    makeEqualHeight ($$(['el-content','el-col1-bot','el-col2']));
    Can anybody please tell me how is this causing the problem?
    Page link: [LINK]
    billyk Friend
    #440856
    that script is causing problems for other stuff on my site, as well. any resolve to this?
    <em>@eastline 125296 wrote:</em><blockquote>I emailed the RS!form component creator about this problem, some of the fields of the form aren’t working on IE and I get a “done with error” notice on IE as well, they replied that their component is operating perfectly and that the error is being triggered by ja.script.js line 67
    Page link: [LINK]</blockquote>
    #441022
    Hi billyk,
    what is your template ? you can post here your url and i will take a look at it for you.
This topic contains 3 replies, has 3 voices, and was last updated by  Sherlock 12 years, 10 months ago.
