  • yamant Friend
    #124661
    I uploaded all quickstart files and directories to my domains root.
    I finished installation procedure without problem.
    Then I deleted installation directory.
    when i try to open my site, internet explorer redirects me to /installation/index.php and IE error page File Not Found (404).
    I can log in to Joomla Administrator of my site without problem. I checked my database, all tables are created.
    Any ideas?
    Michael Casha Friend
    #235334
    Hi yamant,
    You need to upload the latest version of Joomla 1.0.x and then patch the files in the quickstart zip file.
    Hope that helps!
    yamant Friend
    #235335
    Thanks for your quick answer Miccas,
    Justica template uses the last version of Joomla (Joomla! 1.0.13 Stable)
    yamant Friend
    #235336
    Tried again with a new installation, with a different table prefix from jos_.
    The problem stil continues 🙁
    yamant Friend
    #235338
    Problem Update:
    Quickstart install is working at a different directory rather than root ( / ).
This topic contains 5 replies, has 2 voices, and was last updated by  yamant 17 years ago.
