  • mgl908 Friend
    #201017
    I am having a little problem with getting my K2 menus/links to work correctly. I have attached some images etc. to this post and will appreciate pointers in the right direction.
    Thanks in advance.
    1. K2-links.doc
    Ninja Lead Moderator
    #548240
    It’s very hard to get the problem you mentioned but finally, I see the problem from templates/ja_fubix/css/k2.css file, open this file and change as my suggestion
    from
    div.itemContainer {
    float: left;
    padding: 0 0 999em;
    margin: 0 0 -999em;
    background: url(../images/line.gif) repeat-y right top;
    To
    div.itemContainer {
    float: left;
    Let me know if it helps
    mgl908 Friend
    #548292
    <em>@Ninja Lead 444176 wrote:</em><blockquote>It’s very hard to get the problem you mentioned but finally, I see the problem from templates/ja_fubix/css/k2.css file, open this file and change as my suggestion
    from
    div.itemContainer {
    float: left;
    padding: 0 0 999em;
    margin: 0 0 -999em;
    To
    div.itemContainer {
    float: left;
    Let me know if it helps</blockquote>
    It did not work, this is the new code just in case… , Thanks.
    div#itemListLeading div.k2-items-row {
    padding-top: 0;
    div.itemContainer {
    float: left;
    #itemListLeading div.itemContainer:nth-child(2),
    #itemListLeading div.itemContainer:nth-child(4),
    div.itemContainer:nth-child(8),
    div.itemContainer:nth-child(4n) {
    background-image: none;
    #548396
    Is this a problem on your site?
    If you could not solve this bug, you can send me the admin login of your site via private message. I will help you out.
    1. k2_problem
    mgl908 Friend
    #548753
    It’s all okay now. Thanks.
This topic contains 5 replies, has 2 voices, and was last updated by  mgl908 10 years, 2 months ago.
