  • val_rul28 Friend
    #1014822
    I have a problem with drop-down list of the module, does not work.
    I also have problems with the map in the articles, and location data.
    Thanks in advance.
    It’s better with a closer look at your site to detect the issue, you can share the URL and Admin account and some screenshots highlighting the issue.
    val_rul28 Friend
    #1015104
    Mo0nlight Moderator
    #1015538
    You can provide the FTP account, I will try to investigate further.
    val_rul28 Friend
    #1015832
    Mo0nlight Moderator
    #1015948
    Hi.
    The drop-down in administrator does not work because the site had redeclared jquery library.
    </script>
    please find and delete or turn off the extension which renders that.
    and you had to fix the alias of extrafields Latitud -> Latitude Longitude -> Longitude
    The same with multi categories Ubicacin -> Ubicacion MUST be matched the multi-category alias to make it work.
    val_rul28 Friend
    #1016316
    Thaks for your help.
    I don’t understand the problem with:
    "The drop-down in administrator does not work because the site had redeclared jquery library."
    I submit a capture the drop-down in administrator.
    1. Imagen1
    Mo0nlight Moderator
    #1016480
    My bad, it’s wrong typing.
    It had worked because the same alias configuration.
This topic contains 7 replies, has 3 voices, and was last updated by  Mo0nlight 7 years, 8 months ago.
