  • marian_7117 Friend
    #169379
    I have the next problem. When I try to add a new item in K2 Dashboard, I receive an error. “Fatal error: Class ‘JSite’ not found in /home/stiriext/public_html/plugins/system/SEOSimple.php on line 153”.
    My website is http://www.stiriexterne.com
    What can I do?
    Marian
    jooservices Friend
    #417291
    Please PM me your admin account and FTP account then I will check it for you!
    Viet Vu
    jooservices Friend
    #417819
    I’ve just logged into your FTP but invalid password. Please db check it ?
    Thank you
    Viet Vu
    jooservices Friend
    #418090
    I’ve fixed in code but have no backend for checking. So , please check it at your side.
    Thank you
    Viet Vu
    marian_7117 Friend
    #418176
    But my website no longer works now. I see this:
    “Fatal error: Call to a member function getActive() on a non-object in /home/stiriext/public_html/plugins/system/SEOSimple.php on line 155”
    jooservices Friend
    #418640
    #1: Sorry but please re-send me your FPT . I’ve deleted after solve your issue.
    #2. At moment please try to disable SEOSimple plugin. This plugin have some bad core . And i’m trying to fix it.
    Thank you for understand.
    Viet Vu
This topic contains 6 replies, has 2 voices, and was last updated by  jooservices 13 years, 2 months ago.
