  • mangekyou Friend
    #172229
    For instance if i use mod_k2_content to display content i only want to appear on the homepage (blog), when i click an article that belongs in the blogs sub-category/child items the module is still assigned to display on the child items page although i selected the menu assignment just to display in the blog.
    Blog
    – child item 1
    – child item 2
    for example
    mysite.com/blog(where i want the module to appear)/childcategory (still appears here where i don’t want it to)
    How do i correct this?
    Manos Moderator
    #431602
    Have you selected child items to be shown in this menu item also ? If so and if i was able to understand correctly what you are trying to achieve then you should deselect child items.
    I hope that helps you solving the issue, if not please provide me with your web site link so i can take a closer look on that.
    mangekyou Friend
    #431616
    Looks like the solution for this is this module: http://www.nonumber.nl/extensions/advancedmodulemanager?tab=download#description
    thanks anyway
    Manos Moderator
    #431617
    Yeap it’s an option and a good one i must say!! Glad everything works ok for you now! Best Wishes! Hope you have a happy new year!
This topic contains 4 replies, has 2 voices, and was last updated by  Manos 12 years, 12 months ago.
