  • elbeye Friend
    #147939
    can you help me? 🙁
    bryantwest Friend
    #330169
    Maybe… when you open your article in your WYSIWYG editor… click on the image and change the properties to align ‘left’.
    elbeye Friend
    #330175
    i did it but also same 🙁
    bryantwest Friend
    #330176
    Did you try checking the code in the article? (it is an article?)… sometimes things get heywire… check the code to make sure… if not that, recommend delete the image, insert image, and really ensire select ‘left’.
    Looks more like an aligmnet issue that anything. Is it happening to any of your other aticles?
    lamvt Friend
    #330195
    hi, Could you send your Live site , alloe us to help you
    thanks
    elbeye Friend
    #330221
    i cheked article code and changed article image but dont solved
    i will be mad :S
    spencer001 Friend
    #330929
    Hi guy’s same here, I found out that the settings for the pictures in the frontpage only are changed in the JCE editors Advanced tab. It says FLOAT and LEFT.
    If I change it back and save it, it comes back automatically. So it looks like some code error. :confused:
    Is it an JCE issue?
    tjproto Friend
    #331028
    It could be, but I’m getting the same issue and noticed that the image is being rendered before the content is, so I don’t think the contents layout can format the location of the image since it is placed beforehand.
    Example from source code:
    <span><img src="/images/bc1.jpg" border="0" width="280" height="170" style="border: 0; vertical-align: bottom;" /></span>
    </div>
    <div class="article-main">
    <div class="article-content">
    tjproto Friend
    #331032
    Ok, I think I got it. Just remove lines 18-26 in default_item.php, located in /templates/ja_rasite/html/com_content/frontpage/ .
    So, completely remove:
    <?php
    //Get out all images
    $regex = "/<img[^>]*>/";
    $images = '';
    if (preg_match_all ($regex, $this->item->text, $matches)) {
    $this->item->text = preg_replace ($regex, '', $this->item->text);
    $images = implode ("n", $matches[0]);
    Hope that helped.
    simmo Friend
    #332527
    Anyone that now where I can change the thumbnails on frontpage/body from 60×60 to 100×65 ??
    cheers
    simmo
    Hello guy
    You change the size by putting the number into the Intro Images Width param and the Intro Images Height param inside the Thumbnail for Blog view of ja thumbnail plugin.
    good luck
    kavvalos Friend
    #335511
    It working fine thanks
This topic contains 12 replies, has 8 voices, and was last updated by  kavvalos 14 years, 9 months ago.
