Viewing 15 posts - 16 through 30 (of 31 total)
  • ibrahimbdawy Friend
    #333723
    <em>@klmklm 166303 wrote:</em><blockquote>Hi,
    I have installed the Arabic language pack on the template but still have ?????? as the Arabic text. I did not follow on the previous post (ibrahimbdawy)what needed to be don. Is there a way for someone to explain what to do.
    Many thanks in advance. :-*</blockquote>
    Hi,klmklm
    It’s not related to Arabic Language Pack
    This error occurs as a result the database tables for quick start is not Encoding supporting the Arabic language
    open the database tables in Phpmyadmin (c-panel)
    Then follow the steps photos
    I explained to you in Arabic if you want:)
    klmklm Friend
    #333724
    I have done that but still no joy, by all means if you can send the explanation in Arabic would be great but the benefit of all you can leave it in English.
    It is not working as I have followed your instructions what I’ve done looking at the previous post is went to Collation then Operations then changed it from latin1_swedish_ci to utf8_general_ci but this did not resolve the issue
    ibrahimbdawy Friend
    #333725
    <em>@klmklm 166307 wrote:</em><blockquote>Hi,
    I am now abroad, I will explain you the photo will solve the problem
    I understand your problem completely;)
    Please, wait during the 3 hours at the most.
    thanks
    klmklm Friend
    #333726
    You are worth the wait.
    I look forward to hearing from you soon. :-*
    metamar Friend
    #333730
    What is the template name you are using? KLMKLM
    Joomlart tried helping me at first but ultimatly told me this was a joomla problem.
    If you get this resolved, post it! 🙂
    I look forward to hear from you soon too!
    ibrahimbdawy Friend
    #333731
    <em>@klmklm 166310 wrote:</em><blockquote>You are worth the wait.
    I look forward to hearing from you soon. :-*</blockquote>
    hi klmklm
    The first step
    The second step
    The third step
    Thus, in the other tables
    Is a long way
    However, fully guaranteed
    I hope it helped
    metamar Friend
    #333732
    I have tried that using SqlMaestro which converted all my tables but still didn’t fix…I will try this way!
    metamar Friend
    #333733
    yes this fixed it for me
    Joomlart should award you many points!
    And joomlart should have all their templates fixed to have their sample data all in unicode.
    Thank you dearly IbrahimDawy
    Alhamdullilah
    ibrahimbdawy Friend
    #333734
    <em>@metamar 166322 wrote:</em><blockquote>yes this fixed it for me
    Alhamdullilah</blockquote>
    I am happy to resolve your problem 😀 😀
    klmklm Friend
    #333744
    it is a template issue and a Joomla issue as I have run other templates which has Arabic support on and no issues. I am jusing the JA_lime
    Hope to get this sorted soon :-*
    metamar Friend
    #333745
    The problem is that when they created the template they should have used Unicode for their database tables. Because they used Latin collation it gives us the burden of changing the tables one by one. I do hope Joomlart decide to announce that they will fix this issue and update their templates. seems a simple job to do now. If they fix it once then we won’t all have to fix it individually.
    klmklm Friend
    #333747
    Hi ibrahimbdawy
    hope you had a good trip….
    I will try this later on tonight and see what happened…
    Many thanks for what you’ve done, you are fantastic. :-*
    klmklm Friend
    #333770
    You are a star ibrahimbdawy
    I’ve seen other tables with the wrong collation, do I need to change them as well. It is working now, and I can see the Arabic text but seen the other tables and wondering if I should.
    Many Thanks in advance and Salam to you ibrahimbdawy….
    creative_cow Friend
    #334455
    ibrahimbdawy you are great!! Yet i had to do also “ALTER TABLE table CONVERT TO CHARACTER SET utf8 COLLATE utf8_unicode_ci;” for every table of the db. Now everything works (i use greek language)
    Thank you a lot.
    ibrahimbdawy Friend
    #334495
    <em>@creative_cow 167220 wrote:</em><blockquote>ibrahimbdawy you are great!! Yet i had to do also “ALTER TABLE table CONVERT TO CHARACTER SET utf8 COLLATE utf8_unicode_ci;” for every table of the db. Now everything works (i use greek language)
    Thank you a lot.</blockquote>
    you are welcome
This topic contains 31 replies, has 9 voices, and was last updated by  asif_eminov 14 years, 9 months ago.
