  • duh_plumber Friend
    #169115
    i posted before on this subject and have no more views or responce the language filter breaks the menu on the site it has done this from the begining with a fresh site install before i added anything. i cant get a google addsence account till its fixed because they dont understand the language of the site they say. ive included the info to access my site.
    n6rej Friend
    #415758
    sir I found several updates on your site still not done and also a vulnerable version of joomla . I went ahead and upgrade our software .
    I do not see any ja product of ours having to do with language on your site.
    duh_plumber Friend
    #415774
    the install is your quick install and as soon as i did a fresh install and turned on the language filter it broke the menu perhaps you need to update your templates and quick starts. anyways is it working now and ty for looking would you mind telling me what was out of date?
    n6rej Friend
    #415979
    I don’t remember which extensions. I help a lot of customers daily.
This topic contains 4 replies, has 2 voices, and was last updated by  n6rej 13 years, 3 months ago.
