  • zoohayr Friend
    #958064
    Since yesterday, I am unable to install the French language. the latest version of joomla can no longer connect to the server to install the search language ???
    Pankaj Sharma Moderator
    #958095
    Languages installation is not a template feature but a Joomla core feature, we are also not aware of a bug related to languages installation for the 3.6.0 release,
    you can post your question on Joomla.org so Joomla support team help you to fix this bug .
    Or you can install the language pack manually via Joomla installer .
    zoohayr Friend
    #958587
    hi,
    thank you so much ! Regarding the template MovieMax. He is the French version ?
    #958616
    zoohayr Friend
    #958745
    Sorry for my english i use google traduction !
    the template"moviemax" is in English and I wonder if it’s possible to have it in French
    #958746
    This doc helps you to make the site in multilanguage .
This topic contains 5 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 3 months ago.
