Viewing 9 posts - 16 through 24 (of 24 total)
  • Saguaros Moderator
    #527556
    @ msilac,
    I figured out the problem, the reason is that you didn’t create menu for associated language, you had only default menu for HR language only. I just added a new default menu for EN language and enable language switcher module for both languages.
    The flags are showing now, please have a look: http://www.magicosfestival.com/index.php/hr/
    For more info about create a multilanguage site, you can check out this documentation from Joomla: http://help.joomla.org/files/EN-GB_multilang_tutorial.pdf
    Best.
    msilac Friend
    #527602
    What did you mean I didn’t create menu for EN… i did! It is there 2 weeks ago…
    ok, but there is no menu when I click English flag…
    msilac Friend
    #527742
    solved, I found the solution here http://www.joomlart.com/forums/showt…hlight=default
    Hi msilac,
    I meant that with each language, you should create a default menu and assign to it. Previously, your site had only one menu, please check out documentation above for more info.
    Anyways, glad to hear problem is solved now and feel free to let us know if you need further helps.
    Best regards,
    simbim Friend
    #543388
    this link is not working, can some one explain how did the problem solve?
    Basically, after you enable LanguageSwitcher module and ‘Language Filter’ system plug-in, you should create a menu for each language. Within each menu, you set a default menu item for it. Please check out this tips for more info: http://multilingual-joomla-demo.cloudaccess.net/multi-lingual-steps-by-steps.html
    simbim Friend
    #543483
    I already read that, but the problem is that the flags are not appearing, I also followed the video provided by joomlart and it is the same story, I will appreciate an urgent help!
    simbim Friend
    #543484
    <em>@msilac 414529 wrote:</em><blockquote>Hello,
    I have installed 3.2.2 quickstart JA Appolio. I just need couple contents in english and Croatian (local name Hrvatski) – hr-HR) language.
    I have Bonus menu in English and Hrvatski language.
    I have enabled plugins and module
    I have associations between menus.
    But I don’t see menu and flags for choose language.
    Please help</blockquote>
    Can you tell me how did you solve the problem? Thanks 🙂
    You can PM me URL and admin login info of your site, I will have a look.
This topic contains 24 replies, has 3 voices, and was last updated by  Saguaros 10 years, 4 months ago.
