  • rubikonas Friend
    #131067
    I wanted to change lots of english words into lithuanian in the website (i did not find lithuanian version for 1,5)
    Is there any way, I could do it without searching every solution to each small “translate a word” problem?
    For example, I changed the language of date in the top right, but it still remains english in the articles (created, updates) and so I must search where to change it again
    1) Maybe i Could go to english language file and change every word into word i need?
    2) I made some translations and i noticed that i had to use echo comand in the code replacement.
    can anyone write a syntax of that command, so I could change english words to lithuanian
    translations needed (hope to find them in forum
    1. home in the pathway
    2. copyright
    3. all videos tool. (move, close)
    4. many others
    Using Ja Teline II, quickstart
    http://www.piguperku.lt/lietuviu/
    #261049
    Hi !
    You can find Multi-lingual Content for joomla at here
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 16 years, 5 months ago.
