djtaylor Friend
djtaylor
- August 2011
- 2 times in 1 posts
October 31, 2011 at 10:52 pm #170254Hi I think it’s a layout / margin / template problem because there are large spaces between images and texts.
i was told it maybe to do with the template.css, but i do not know how to correct it am afraid of messing up the template
can anyone tell me what needs changing please
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
October 31, 2011 at 11:52 pm #422658What link/page is depicted in your example?
djtaylor Frienddjtaylor
- August 2011
November 1, 2011 at 6:47 am #422730http://thatmixtape.com/index.php/component/muscol/U/6-urban-noize/4-brooklyn-chicago-london
<em>@TomC 280078 wrote:</em><blockquote>What link/page is depicted in your example?</blockquote>
- August 2011
November 1, 2011 at 11:53 am #422772anyone know how to do this been waiting for a reply for a while?
TomC ModeratorTomC
- October 2014
November 2, 2011 at 2:16 am #422862<em>@djtaylor 280218 wrote:</em><blockquote>anyone know how to do this been waiting for a reply for a while?</blockquote>
Apologize for the delay . . .
Okay, for the area for the two headings, it appears that the CSS controlling this element/area can be found within the following path:
plugins/system/jat3/jat3/base-themes/default/css/template.css
at line 37, you will see …
/* Content spacing ---*/
.column p, .column pre, .column blockquote,
.column h1, .column h2, .column h3, .column h4, .column h5, .column h6,
.columnol, .columnul, .columndl { margin: 15px0; padding: 0; }
The culprit appears to be the margin setting – so my recommendation would be to experiment with different variables (including, perhaps, a negative value for “margin-top” (i.e. -10px))
As an added bit of advice, I would recommend utilizing a tool such as FIREBUG to assist you in identifying various web layout elements as you continue to develop your site. This is the kind of tool many of the Support Team use.
SEE HERE for INFO –> http://www.joomlart.com/forums/topic/using-firebug-to-customize-your-site/
- August 2011
November 2, 2011 at 7:26 am #422902Hi thanks for your great help Tom, the best i can have is margin 0px as any more the text goes over its self but thats way better than before
thanks so much for your time and for the firebug info and link also 🙂<em>@TomC 280341 wrote:</em><blockquote>Apologize for the delay . . .
SEE HERE for INFO –> http://www.joomlart.com/forums/topic/using-firebug-to-customize-your-site/</blockquote>
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 2 voices, and was last updated by djtaylor 13 years ago.
large spaces / layout / margin problem ?
