  • mrfast Friend
    #165595
    I use Ja_comment v1.1.1 and install full package include plugin and modules.
    I have problem with mod_jaclatest_comments both case “Show latest comment” and “Show popular comment“. More detail please attach file.
    for test case online please visit http://zeolite2.fast.com.vn
    thanks for any tip or stick to solve this bug.
    @ ja staff: please reply as soon as possible (thanks)
    1. bug-ja_comment
    mrfast Friend
    #399496
    Support ticket, on: 27 June 2011 06:20 PM
    I’m trying to debug your issue to find out the reason why this problem occurs. It takes me a lot of time. I will inform you when this issue is fixed ASAP.
    Thanks for your patience.
    Best regards,
    Nhat Nguyen Xuan
    JoomlArt Customer Service.
    J.O.O.M Solutions Co., Ltd
    http://www.joomlart.comhttp://www.joomlancers.com
    @staff: This bug I have report one week ago but today can not solve. Please let me know deadline to fix it.
    Some testimonials for product: This component is commercial product but worse than free products it have many basic bug and so long to fix. I do not understand why they can sell a product not good.
    mrfast Friend
    #399721
    Here is message I receive from ja-staff he still neither let me know when complete.
    Posted on: 01 July 2011 05:41 PM
    For the 1st problem, it isn’t a problem of JA Comment. It’s a feature of mod_jaclatest_comments. It shows all latest comments even their replies.
    For “don’t show title” problem, I am working on it and it takes me a lot of time to do. I will inform you when I finish ASAP.
    Thank you.
    Best regards,
    Nhat Nguyen Xuan
    [/quote]
    And here is auto message I receive form support center
    Fast,
    This message concerns your ticket #DYE-594-25131. We have not received any response back from you in 48 hours, and would like to know if you consider this issue to be resolved. If you have any further questions, simply respond to this e-mail.
    Ticket ID: DYE-594-25131
    Subject: lastest comment and popular work not right
    Department: Technical – JAEC
    Type: Issue
    Status: Replied
    Priority: High
    Please note that the ticket will automatically be closed within 72 hours if no response is received from you. The ticket will not be closed in the case that you send another reply. You can check the status of or reply to this ticket online at: http://support.joomlart.com/index.php?/Tickets/Ticket/View/DYE-594-25131
    Kind regards,
    JoomlArt
    ________________________________________
    Support Center: http://support.joomlart.com/index.php?
    I still do not know what they are doing and and how long they can solve this problem.
    @Ja-Staff: PLEASE, Let me know deadline you can solve it.
    mrfast Friend
    #400530
    Three weeks not solve basic bug for developer plan. Have anybody let me know how many week this bug will solve or never.
    ironically for slogan design professional, support when need it… bla bla bla
    Stork11 Friend
    #400868
    The “don’t show title” problem is resolved. Please check and confirm the same.
    I also reply you at ticket http://support.joomlart.com/index.php?/Tickets/Ticket/View/75509
    Thank you.
    mrfast Friend
    #408860
    Hi Nhat,
    I have double check newest version ja_commenet.v.1.1.1 it’s work not good. I have remove old version ja_comment.v1.1.0 and reinstall newest version but can not solve problem can not show title of article if reply from admin panel, check at http://zeolite2.fast.com.vn
    Please review ticket #DYE-594-25131
    Problem 2: Do not have data to compare JA Comment plugin for Joomla 1.5 and JA Search JA Comment module for Joomla 1.5
    Please review ticket #ITU-727-62312 and update it’s. Over 24h but do not have any reply >:(
    Stork11 Friend
    #409335
    Hello mrfast,
    The problem is resolved. Please check and confirm the same.
    I also applied this fix to next version of JA Comment.
    Thank you for your report.
    mrfast Friend
    #409598
    Mr Nhat have resolved issue don’t display title but function limit chars for content title do not apply for reply from admin. Anybody can let me know how can apply limit chars for reply from admin.
    Thanks.
    mrfast Friend
    #409599
    Thanks.
    Stork11 Friend
    #409603
    Hello mrfast,
    I add the following line into “parseItems” function in “modules/mod_jaclatest_comments/helper.php” file (about line 152):
    $item->contenttitle = empty($item->contenttitle) ? $item->content_title : $item->contenttitle;
    It fixed the problem.
    Best regards.
    mrfast Friend
    #409977
    Modules ja_latest_comment have a big bug. It can not update link to articles when change menu name(include alias)
    Example: http://zeolite2.fast.com.vn/test-layouts.html
    When I change menu “Layouts” to “TEST Layouts” then all link(from comment) to these article have break.
    Please view ticket #DYE-594-25131 and update and fix this bug as soon as possible.
This topic contains 11 replies, has 2 voices, and was last updated by  mrfast 13 years, 4 months ago.
