September 30, 2011 at 1:50 am #169121
Hi: Comments are not showing up in the module. everything else shows okay and then “Username said: BLANK.”
I’ve looked everywhere and there seems to be no reason why this is happening. Please help
what am i missing? Screen shot is attached.
jooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
September 30, 2011 at 3:14 am #415783Hi
Please update me with your backend access and FTP for checking
Thank you
Viet VuSeptember 30, 2011 at 6:28 am #415825I’ve PMed you the backend info and FTP as requested. Thanks a bunch 🙂
- October 2014
September 30, 2011 at 6:31 am #415826Hi
Please db check your site , your FTP access can logging but empty directory ?
Thank you
Viet VuSeptember 30, 2011 at 6:48 am #415832oops! please try it again…made a mistake in creating the ftp account. Please let me know rightaway if this works fine. thank you.
- October 2014
September 30, 2011 at 7:18 am #415838Hi
It should be done now, please try again at your side ( clear cache before )
Thank you
Viet VuOctober 1, 2011 at 12:01 pm #416008Hi,
I am facing same problem in my development environment, please, can you share the solution?
Thany you,
Sergiojooservices Friendjooservices
- October 2014
October 1, 2011 at 12:02 pm #416009Hi
For each topic please only one owner. If you have trouble please create new one than i can help you 🙂
Thank you
Viet VuAuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 3 voices, and was last updated by jooservices 13 years, 2 months ago.
Latest Comment module issue – Comment is NOT showing
