  • harveyfawcett Friend
    #127740
    Hi all,
    I am in the early stages of a site development and have run into problems with IE6 layout.
    The problem seems to be with Google Ads. I use FlexAdvert and have never run into this before. All other ads display OK, whether local or hosted remotely and everything seems fine in Firefox and IE7
    When viewed in IE6 the advert block which is normally in the right position drops below the content on the left. The site is at http://www.sgtslingsby.com
    Joomla 1.0.15, Flexadvert and no other components installed yet
    Latest version of Edenite with no modifications
    I have asked the FlexAdvert developer the same question but given it seems to be a layout issues thought I would put it up here as well. When I use another template the problem goes away
    Thanks in advance
    TomC Moderator
    #246219
    #246391
    Tried that, still got the problem
    mflores Friend
    #247286
    Hello sir. Were you able to fix it? I am still trying to figure it out.
    Thanks!
    martin
    TomC Moderator
    #247327
    So, you both inserted the IE6 hack as recommended in [url=http://www.joomlart.com/forums/topic/dealing-with-ie6-special-hackcss/
    I had a very similar problem in dealing with IE6 layout and that hack and steps corrected the problem.
    It may take some additional tweaking / experimentation.
This topic contains 5 replies, has 3 voices, and was last updated by  TomC 16 years, 7 months ago.
