  • shmily Developer
    #204234
    I have added a module position for placing graphic above main navigation (Purity III template.)
    In the admin “layout” section it shows position above but on front end I cannot get it to appear over the menu.
    Pankaj Sharma Moderator
    #561126
    Hello
    The default module position like search module is defined in the main nav like this >>>> http://prntscr.com/6bm3i3
    I am not sure what changes you have done to add module position ,
    Here is a guide to create new module positions .
    If module position not working as given in doc . Share the changes details that you done and your working site url here .
    shmily Developer
    #561971
    I resolved issue but exactly sure how?/:) As always I appreciate your responses.
    #561975
    Glad you sort it . If you have any issue related to module position update here .
    Thanks .
This topic contains 4 replies, has 2 voices, and was last updated by  Pankaj Sharma 9 years, 10 months ago.
