  • daria_kas Friend
    #909857
    Some modules are not working properly. Please take a look. What could be causing such problem?
    daria_kas Friend
    #910272
    I just installed template with sample data. i have not added anything or changed anything
    Ninja Lead Moderator
    #910463
    I have just downloaded JA Healthcare template and installed it at my end, but I could not see the problem as your site: http://cl.ly/3X3k1P1p0745
    You can try to download quickstart package from here and install it again.
    daria_kas Friend
    #911365
    thanks a lot. that was the problem. something went wrong during download.
    I have a question about flaticon. I want to add a completely different flaticon then the ones pre installed. i cannot find where are the image files for these icons. where can i declare a new class of flat icon…say :flaticon_taxi.
    #912035
    You can find the font from JA Healthcare template templates/ja_healthcare/fonts/flaticon folder and the way to load it from templates/ja_healthcare/etc/assets.xml file
    <file>fonts/flaticon/font/flaticon.css</file>
This topic contains 4 replies, has 2 voices, and was last updated by  Ninja Lead 8 years, 8 months ago.
