August 6, 2007 at 1:08 am #121858
I’m running into a problem when I view the site in Internet Explorer 6. Here is the site:
http://www.davidhperry.com/new3/Take a look at it with Firefox and then with IE. You’ll notice the the middle section is cut off in IE. Does anyone have and ideas for how to fix this?
August 6, 2007 at 4:35 am #226440I’ve tested it further and the page appears to load correctly but then the bottom blue (default color grey) section jumps up to cover some of the text in the middle portion.
It looks like the same thing as described here:
http://www.joomlart.com/forums/topic/funny-problem-with-all-extras/August 10, 2007 at 4:35 am #226744Does anyone have ideas on how to solve this? We’re ready to use the template but we can’t launch the site without figuring out the IE issue.
Menalto FriendMenalto
- May 2007
- 531 times in 361 posts
August 10, 2007 at 12:37 pm #226769Working on it,and hope to have it solved soon
pimmar Friendpimmar
- June 2007
- 6 times in 1 posts
August 16, 2007 at 8:20 pm #227236Hi Menalto,
I experience the same problem on a site I build: http://www.vvsv.nl
Will you post the solution you’ve found in this forum?Thnx!
- May 2007
August 19, 2007 at 8:12 am #227460<em>@Pimmar 24672 wrote:</em><blockquote>Hi Menalto,
Will you post the solution you’ve found in this forum?Thnx!</blockquote>
I have the solution, but im not sure if it’s a bug in the template or not, atleast i have make it work the way it should work for davidhperry.
Hook me up on skype or google talk and i can help you out if you want?August 20, 2007 at 6:17 pm #227625Menalto,
I am having a strange problem with JA slideshow. The problem is happening in ie 6 but not ie 7. The slideshow lines perfectly with the content pane but it is somehow causing the modules on the right to move downwards and a huge gap is created on right because of this.
The slideshow currently just has one image. Both the slideshow module and image are set to 673 x 150.
I don’t know if this is a similar issue. I am almost done with the template and would like to release it soon.
Thanks for your help.
- May 2007
August 20, 2007 at 9:50 pm #227644<em>@tsorial 25161 wrote:</em><blockquote>Menalto,
Thanks for your help.</blockquote>
Can you please PM me your site url?Or post it here?
August 22, 2007 at 1:29 am #227765<em>@Menalto 24967 wrote:</em><blockquote>I have the solution, but im not sure if it’s a bug in the template or not, atleast i have make it work the way it should work for davidhperry.
Hook me up on skype or google talk and i can help you out if you want?</blockquote>I’m having this problem too…. :(( Can you help me out?
Thanks,
NealeAugust 26, 2007 at 3:24 am #228139<bump>
Can anyone help me with this? …please! 😀
- May 2007
August 26, 2007 at 4:46 am #228140BUMP,yes.Contact me by google talk or skype and lets see how things are going.
August 27, 2007 at 7:30 pm #228231I’ve sent you a PM… thanks!
March 12, 2008 at 1:27 pm #242044I would like to know what is the point of PM anyone on the forum, I have similar problems and it would be nice if you can let us know in this forum what the solution is instead of pm each other.:D
mj1256 Friendmj1256
- June 2007
- 225 times in 118 posts
March 14, 2008 at 4:12 pm #242225Was this ever solved???
March 31, 2008 at 3:44 pm #243765Menalto–
<em>@Menalto 25833 wrote:</em><blockquote>BUMP,yes.Contact me by google talk or skype and lets see how things are going.</blockquote>
PMed you last Tuesday (3/25) re: this issue with my site info … please reply either via PM or on this forum. Thanks in advance.
This topic contains 15 replies, has 8 voices, and was last updated by matthew123456 16 years, 8 months ago.
